having an issue with a project it has two layers one line (cut), one a fill layer that part works great but when I tell it to start it does the fill followed by the cut layer problem is the power of he laser it is so low it barely leaves a mark on the paper. with each layer the power is set at 100% and normal speeds I would use for that function. laser is an ATOMSTACK S10. This is my first time using Lightburn. what am I missing Thanks
What is the specific speed setting that you’re using? Please include the units designation as well.
Also, check Edit->Device Settings. What is the S Value Max value set there?
