Good Afternoon Everyone,
I was wondering if anyone sees an issue with this? My laser keeps turning off mid burn, I had an Ortur LM2, Sent that back and got a FoxAlien 15W. The laser will stop and keep firing in one spot, sometimes it just stops anywhere from 3 minutes to 25 minutes is the farthest i’ve made it in a project so far… Here is the console from the first issue;
Grbl 1.1h [’$’ for help]
ok
[VER:1.1h.20190825:]
[OPT:V,15,128]
Target buffer size found
ok
Project loaded in 1150 milliseconds
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=0
$24=2500.000
$25=2500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$100=80.000
$101=80.000
$102=80.000
$110=3000.000
$111=3000.000
$112=3000.000
$120=400.000
$121=400.000
$122=400.000
$130=400.000
$131=400.000
$132=200.000
ok
Starting stream
[MSG:Pgm End]
Stream completed in 0:04
ok
ok
ok
ok
ok
Starting stream
Stream completed in 0:02
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
ok
[MSG:’$H’|’$X’ to unlock]
[MSG:Caution: Unlocked]
ok
Starting stream
Stream completed in 0:17
Starting stream
Stream completed in 0:15
Starting stream
Stream completed in 0:14
Starting stream
Starting stream
Stream completed in 5:20
ok
[OPT:V,15,128]
ok
Any help is greatly appreciated, USB settings are adjusted, the display settings are adjusted, i’m running the laser in “Synchronous” mode, i’m not sure what I am missing here…
