Laser printing wrong size
Hello,
I have a Full Spectrum MLE-40 Smoothieware using a SmoothieBoard v1.1 as a controller. the laser fires and engraves, but images come out off-scale/wrong size. A square 100x100mm comes out as 229mm wide by 70mm high. I have changed the steps per mm in the configuration with no changes at all. I ran the same test in another smaller laser running on grbl with the same results. The edit tab is not showing the machine settings option.
Please help.
Is this a duplicate post? Please delete one of these as it can be confusing and split the discussion.
