So I have a omtech k40+ was Lasering things fine then I was trying to get my Image center better don’t know what I hit now after I hit Frame it frames out fine then when I go to hit start the laser rappers to the bottom right corner ? And I have to hit emergency stop ? I’m new at this and this is my sec time using the machine
What is the Start From mode in Laser window set to? I’d suggest sticking with Absolute Coords until until you’re very familiar with LightBurn and your laser.
I’ll take a look at that and get back with you thanks you
That did not work
To what corner of the machine does it home?
Run these commands in Console and return the output please:
$H
$I
Also, please take a full screenshot of LightBurn with your design loaded.
It gos home to the top left corner always
As soon as I get home I will do all this and seen you a screen shot thank you
Can you run those commands that I listed previously?
