Laser running older cut, not current file. How do I purge jobs?
I am setting up a new OmTech Polar laser and having problems with the z axis AND the laser running a job that I have finished when I push start on my current file. I am connected via USB from my Windows 10 laptop to the USB port on the laser. I found a thread that said to open the file tab and clear/reset but there is nothing like that on my file menu. Thanks in advance.
You can do it from the Ruida console under file or from Lightburn in the files tab in the cut/layers window, I believe. The machine isn’t up for me to check…
You may have to go to Window → File list to enable it…
Don’t do a factory reset of the controller… you will lose all of your vendor settings…
