Why would the laser start running really fast, not engrave and be really jerky
- Layer speed is set high
- Layer power is set low
- Laser power supply is off
- Acceleration is set too high
- Velocity is set too high
- Holding torque is set too high
- The laser is being operated in a zero gravity environment
There is not much detail in the question, so the answers above are of a very general nature.
Take some time and explore the forum. Read a little bit from search results. Try searching on keywords you may think are related to your issue.
Imagine if your question read:
“Why would my car start to run really fast, lose steering, and ride really rough”. So many reasons for each one of those situations individually.
I have tried the speed setting but it just all.of a sudden started doing it. Laser comes on but won’t cut and its almost seem uncontrollable also makes a noise when framing
What speed are you using, including units? (50 mm/sec, 3000 mm/min, … ?)
You might have accidentally enabled “inches” mode, for example, and a setting of 3000 inches/min would be MUCH faster than 3000 mm/min.
