Example: one long line - the laser tracks the line then slows for a second then back to original speed. Why would this happen? The line should be the same over the entire length. This result is some sections are cut through while others sections are only burned. Any thoughts?
Is it actually just a line, or is it part of an image?
If it is truly just a line, is it possible that there is more than one segment in the line? Look at it in ‘Node Editing’ mode to see if there are extra points.
For example, I’ve made this line - the top one is not selected, and the bottom one is a copy I’ve made, and is displaying in Node Edit mode so you can see all the extra points:
