I am trying to engrave an item with my xtool d1, I line everything up using set laser position tool, hit start and it veers to the right side of engraver grinding the motors gears. This is my first print while using lightburn so no prior history. Have tried using multiple “start from” and all still veer right. Have tried to update the firmware but it is up to date. I have its home set to the top left of the engraver. Orgin is set to the top left.
Figured out the problem. In device settings the initial offset was somehow adjusted by 3,000,000,000 somehow. I clicked delete on both of them obnoxious numbers and it is working as expected.
