Hello,
I am having some issues with my laser not engraving all lines on an image.
The first image is how the result should look and the second one is how it turned out. I did some research and the results consisted of looking at the physical y-axis. But, this cutter was working just fine until I upgraded the controller. So I assume it is something software-related (power or speed perhaps).
Yep, this was the problem. Going too fast over those lines. I took the speed down to 50 mm/s. It still needs some fine tuning but that will come with time.
