Laser speed changing on it's own when opening file not transferring correct speed to laser
Hi new here… I have Aeon Mira 9 laser and recently have had an issue with the software changing my set speed in my files when I open them also when I change it back it does not transfer my changes correctly. the photos show what the speed was when I opened it the next is what it should have been and the last is the speed it sent to the laser should have been 17 not 7
If you read your 2 sent images you will find that you are using 2 different units of measurement.
Set either everything to mm or everything to inches, depending on what you prefer.
Hi Allison and welcome.
LightBurn is in in/m and the laser in mm/s.
If you are expecting the layers to retain your settings for a new project, check out the 3 buttons at the bottom of the Cuts Editor window.
When you save a project, and later open it up, your settings will be the same as where you left them.
How do you set the Ruida to inches? I thought it only did mm? I guess Lightburn is converting thing?
:grinning_cat:
It might be a KT-332N thing:
Selecting inch would likely produce painful results, although it may be only for the display, with the control inputs remaining in metric.
Nevertheless, I ain’t going there. :face_with_head_bandage:
I can change everything same as yours but the inch/mm option doesn’t seem to appear.
:grinning_cat:
It was in LB of course that it should be changed.
