Laser stays Busy
Hello,
i.am 3 days waiting for my laser to work again.
Runn
[MSG:Screen Uart_RX:GPIO(42), Uart_TX:GPIO(41)]
[MSG:Grbl_ESP32 Ver 1.3a Date 20211103]
[MSG:Compiled with ESP32 SDK:-128-NOTFOUND]
[MSG:FlameSensor on pin GPIO(4)]
[MSG:Buzzer on pin GPIO(1)]
[MSG:I2C SCL on pin GPIO(18), I2C SDA on pin GPIO(17), AccelSensor on pin GPIO(8)]
[MSG: Correct ID:0x33]
[Board:LGT LASER RAY5 V1.1]
[Machine:Longer Laser Ray5]
[Software:v1.9.11]
[Wavelength:460nm]
[Working Size:XSIZE=400.00:YSIZE=400.00]
[MSG:Axis count 2]
[MSG:RMT Steps]
[MSG:Init Motors]
[MSG:Global stepper disable pin:GPIO(3)]
[MSG:X Axis Standard Stepper Step:GPIO(14) Dir:GPIO(9) Disable:None Limits(0.000,400.000)]
[MSG:Y Axis Standard Stepper Step:GPIO(16) Dir:GPIO(15) Disable:None Limits(0.000,400.000)]
[MSG:Laser spindle on Pin:GPIO(7), Enbl:None, Freq:1000Hz, Res:14bits Laser mode:On]
[MSG:Local access point LongerLaser_01E0 started, 192.168.0.1]
[MSG:Client Started]
[MSG:Connecting deco huis]
No sd card,Please insert sd card[MSG:Flood coolant on pin GPIO(19)]
[MSG:X Axis limit switch on pin GPIO(6)]
[MSG:Y Axis limit switch on pin GPIO(5)]
Grbl 1.3a [‘$’ for help]
[MSG:Connection failed, attempting to reconnect] Runn
[Software:v1.9.11]
[Wavelength:460nm]
[MSG:Axis count 2]
[MSG:RMT Steps]
[MSG:Init Motors]
anybody know what i am doing wrong.
thanks
jan
Check in your Device Settings under Basic Settings. See if you have “Enable DTR Signal” on.
thanks problem solved i am very happy.
greating jna from holland
