Sevvn
(Shawn Yates)
November 10, 2020, 6:47pm
1
Hi all,
Any help or ideas here is greatly appreciated!
I have a Shapeoko XXL (GRBL) with a SmartSain laser attached.
https://www.amazon.com/gp/product/B07VHJ7JNW/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
The fire button properly turn the laser on and off. But when running the cut sequence, the laser is on just a little for travels and stays on at the end of the routine. I click fire button twice after the routine and it turns the laser off.
Here are my $$ settings.
$0=10
$1=255
$2=0
$3=2
$4=0
$5=0
$6=0
$10=0
$11=0.020
$12=0.010
$13=0
$20=0
$21=0
$22=1
$23=0
$24=100.000
$25=2000.000
$26=25
$27=3.000
$30=255
$31=0
$32=1
$100=40.000
$101=40.000
$102=200.000
$110=10000.000
$111=10000.000
$112=1000.000
$120=500.000
$121=500.000
$122=270.000
$130=845.000
$131=850.000
$132=95.000
In Edit > Device Settings, what is the ‘S-value Max’ number set to?
And double check the $32 setting - some machines automatically revert that number after reset. I know X-Carve does it, but I’m not sure about Shapeoko.
Sevvn
(Shawn Yates)
November 12, 2020, 3:06pm
3
Thanks for taking time to reply! I really appreciate it.
My Smax is 255
That $$ dump was taken right after executing my User Laser macro which is -
$10=0
$30=255
$32=1
G10 L2 P1 X-812 Y-812
I don’t power off the router before running it so I am pretty sure that the $$ shown is accurate.
Which version of GRBL firmware are you running on the machine? It should tell you when it connects.
Sevvn
(Shawn Yates)
November 12, 2020, 6:46pm
5
Here is the sequence I see at startup (I stopped it in the middle of homing)
Looks like 1.1f
Waiting for connection…
Grbl 1.1f [’$’ for help]
[MSG:’$H’|’$X’ to unlock]
[MSG:Caution: Unlocked]
ok
[VER:1.1f.20170131:]
[OPT:VNPR,14,128]
Target buffer size found
ok
Homing
Sevvn
(Shawn Yates)
November 12, 2020, 6:52pm
6
Incidentally, it does look like $30 is stored when powered down and back up. This $$ was pulled after power up before running the macro (but after having run it a few days ago and then turning the router off)
$0=10
$1=255
$2=0
$3=2
$4=0
$5=0
$6=0
$10=0
$11=0.020
$12=0.010
$13=0
$20=0
$21=0
$22=1
$23=0
$24=100.000
$25=2000.000
$26=25
$27=3.000
$30=255
$31=0
$32=1
$100=40.000
$101=40.000
$102=200.000
$110=10000.000
$111=10000.000
$112=1000.000
$120=500.000
$121=500.000
$122=270.000
$130=845.000
$131=850.000
$132=95.000
ok
It’s supposed to be, but some controller makers force it to reset on power up. I don’t see anything in your settings that indicate a problem, so I’d check wiring and grounding.
Sevvn
(Shawn Yates)
November 12, 2020, 7:40pm
8
The thing that led me away from hardware though is the fact that the fire laser button in LightBurn works perfectly. Click- laser on. Click - laser off.
But, during a programmed burn, the laser stays on all the time
None the less, there are only like 5 or 6 wires so I will recheck them.
Try making a job that would leave the laser on, but instead of running the file, click ‘Save GCode’ and post the saved gcode here so I can see it.
Sevvn
(Shawn Yates)
November 12, 2020, 8:31pm
10
; LightBurn 0.9.18
; GRBL device profile, current position
; Bounds: X-1.06 Y0 to X54.52 Y10.86
G00 G17 G40 G20 G54
G91
M4
; Scan @ 200.0001 in/min, 50% power
M9
G0X0.6015Y0.0341
; Layer C01
G1X0.0833F200S0
G1X0.0186S127.5
G1X0.0833S0
G1X0.0113Y0.0125S0
G1X-0.0834S0
G1X-0.0183S127.5
G1X-0.0099S0
G1X-0.003S127.5
G1X-0.0833S0
G1X0.0235Y0.0125S0
G1X0.0833S0
G1X0.0136S127.5
G1X0.0833S0
G1X1.0818Y0.0125S0
G1X-0.0833S0
G1X-0.0143S127.5
G1X-0.0359S0
G1X-0.0143S127.5
G1X-0.0361S0
G1X-0.0143S127.5
G1X-0.0344S0
G1X-0.0463S127.5
G1X-0.0369S0
G1X-0.0445S127.5
G1X-0.0364S0
G1X-0.0165S127.5
G1X-0.0367S0
G1X-0.0476S127.5
G1X-0.0338S0
G1X-0.0145S127.5
G1X-0.0401S0
G1X-0.0143S127.5
G1X-0.0344S0
G1X-0.0463S127.5
G1X-0.0435S0
G1X-0.0472S127.5
G1X-0.0266S0
G1X-0.0175S127.5
G1X-0.0349S0
G1X-0.0143S127.5
G1X-0.0217S0
G1X-0.0143S127.5
G1X-0.022S0
G1X-0.0144S127.5
G1X-0.0228S0
G1X-0.0129S127.5
G1X-0.0068S0
G1X-0.0407S127.5
G1X-0.0416S0
G1X-0.0471S127.5
G1X-0.0511S0
G1X-0.0177S127.5
G1X-0.0454S0
G1X-0.0132S127.5
G1X-0.0046S0
G1X-0.0394S127.5
G1X-0.0455S0
G1X-0.0462S127.5
G1X-0.0447S0
G1X-0.0465S127.5
G1X-0.0462S0
G1X-0.0178S127.5
G1X-0.0312S0
G1X-0.0179S127.5
G1X-0.0834S0
G1X-0.0038Y0.0125S0
G1X0.0833S0
G1X0.0251S127.5
G1X0.0245S0
G1X0.0251S127.5
G1X0.0313S0
G1X0.0168S127.5
G1X0.0347S0
G1X0.0174S127.5
G1X0.0224S0
G1X0.017S127.5
G1X0.0347S0
G1X0.0173S127.5
G1X0.0233S0
G1X0.0162S127.5
G1X0.0316S0
G1X0.0197S127.5
G1X0.0407S0
G1X0.0133S127.5
G1X0.0009S0
G1X0.0129S127.5
G1X0.0356S0
G1X0.017S127.5
G1X0.0346S0
G1X0.0174S127.5
G1X0.0237S0
G1X0.0163S127.5
G1X0.0308S0
G1X0.0201S127.5
G1X0.0228S0
G1X0.0144S127.5
G1X0.022S0
G1X0.0143S127.5
G1X0.0217S0
G1X0.0143S127.5
G1X0.0268S0
G1X0.0173S127.5
G1X0.0239S0
G1X0.0176S127.5
G1X0.0344S0
G1X0.017S127.5
G1X0.0219S0
G1X0.017S127.5
G1X0.0345S0
G1X0.0173S127.5
G1X0.0227S0
G1X0.0143S127.5
G1X0.0401S0
G1X0.0145S127.5
G1X0.023S0
G1X0.0178S127.5
G1X0.0345S0
G1X0.017S127.5
G1X0.0683S0
G1X0.0164S127.5
G1X0.033S0
G1X0.0156S127.5
G1X0.016S0
G1X0.017S127.5
G1X0.0347S0
G1X0.0172S127.5
G1X0.0226S0
G1X0.0143S127.5
G1X0.0361S0
G1X0.0143S127.5
G1X0.0359S0
G1X0.0143S127.5
G1X0.0833S0
G1Y0.0125S0
G1X-0.0833S0
G1X-0.0143S127.5
G1X-0.0359S0
G1X-0.0143S127.5
G1X-0.0361S0
G1X-0.0143S127.5
G1X-0.0184S0
G1X-0.0152S127.5
G1X-0.0471S0
G1X-0.015S127.5
G1X-0.0148S0
G1X-0.0076S127.5
G1X-0.0434S0
G1X-0.015S127.5
G1X-0.1227S0
G1X-0.0149S127.5
G1X-0.019S0
G1X-0.0145S127.5
G1X-0.0401S0
G1X-0.0143S127.5
G1X-0.0186S0
G1X-0.0152S127.5
G1X-0.047S0
G1X-0.015S127.5
G1X-0.0759S0
G1X-0.015S127.5
G1X-0.028S0
G1X-0.017S127.5
G1X-0.0187S0
G1X-0.0143S127.5
G1X-0.0217S0
G1X-0.0143S127.5
G1X-0.022S0
G1X-0.0144S127.5
G1X-0.0228S0
G1X-0.0148S127.5
G1X-0.0394S0
G1X-0.0144S127.5
G1X-0.0183S0
G1X-0.0152S127.5
G1X-0.047S0
G1X-0.015S127.5
G1X-0.0268S0
G1X-0.0139S127.5
G1X-0.0083S0
G1X-0.0143S127.5
G1X-0.0359S0
G1X-0.0141S127.5
G1X-0.0432S0
G1X-0.0146S127.5
G1X-0.0148S0
G1X-0.0152S127.5
G1X-0.047S0
G1X-0.015S127.5
G1X-0.0144S0
G1X-0.0151S127.5
G1X-0.047S0
G1X-0.015S127.5
G1X-0.0231S0
G1X-0.013S127.5
G1X-0.0059S0
G1X-0.0134S127.5
G1X-0.0179S0
G1X-0.0124S127.5
G1X-0.0066S0
G1X-0.0132S127.5
G1X-0.0833S0
G1X-0.0039Y0.0125S0
G1X0.0834S0
G1X0.0136S127.5
G1X0.0133S0
G1X0.0124S127.5
G1X0.0113S0
G1X0.0134S127.5
G1X0.0129S0
G1X0.0132S127.5
G1X0.018S0
G1X0.0148S127.5
G1X0.0498S0
G1X0.0147S127.5
G1X0.0123S0
G1X0.0147S127.5
G1X0.0499S0
G1X0.0147S127.5
G1X0.0124S0
G1X0.0147S127.5
G1X0.0456S0
G1X0.013S127.5
G1X0.0311S0
G1X0.0147S127.5
G1X0.0172S0
G1X0.0141S127.5
G1X0.021S0
G1X0.0147S127.5
G1X0.0499S0
G1X0.0147S127.5
G1X0.0172S0
G1X0.0144S127.5
G1X0.04S0
G1X0.0143S127.5
G1X0.0228S0
G1X0.0144S127.5
G1X0.022S0
G1X0.0143S127.5
G1X0.0217S0
G1X0.0237S127.5
G1X0.0013S0
G1X0.0166S127.5
G1X0.0352S0
G1X0.078S127.5
G1X0.013S0
G1X0.0148S127.5
G1X0.0498S0
G1X0.0147S127.5
G1X0.0176S0
G1X0.0143S127.5
G1X0.0401S0
G1X0.0145S127.5
G1X0.0178S0
G1X0.0779S127.5
G1X0.0599S0
G1X0.0146S127.5
G1X0.0661S0
G1X0.0147S127.5
G1X0.0498S0
G1X0.0148S127.5
G1X0.0175S0
G1X0.0143S127.5
G1X0.0361S0
G1X0.0143S127.5
G1X0.0359S0
G1X0.0143S127.5
G1X0.0833S0
G1Y0.0125S0
G1X-0.0833S0
G1X-0.0144S127.5
G1X-0.0355S0
G1X-0.0146S127.5
G1X-0.0353S0
G1X-0.0151S127.5
G1X-0.0187S0
G1X-0.015S127.5
G1X-0.0468S0
G1X-0.0152S127.5
G1X-0.0657S0
G1X-0.0151S127.5
G1X-0.0621S0
G1X-0.0146S127.5
G1X-0.0459S0
G1X-0.0146S127.5
G1X-0.0195S0
G1X-0.0145S127.5
G1X-0.0392S0
G1X-0.0151S127.5
G1X-0.0188S0
G1X-0.015S127.5
G1X-0.0469S0
G1X-0.015S127.5
G1X-0.0155S0
G1X-0.0145S127.5
G1X-0.0458S0
G1X-0.0149S127.5
G1X-0.0419S0
G1X-0.0173S127.5
G1X-0.0048S0
G1X-0.0143S127.5
G1X-0.0217S0
G1X-0.0143S127.5
G1X-0.022S0
G1X-0.0144S127.5
G1X-0.0228S0
G1X-0.0143S127.5
G1X-0.04S0
G1X-0.0144S127.5
G1X-0.0184S0
G1X-0.015S127.5
G1X-0.0468S0
G1X-0.015S127.5
G1X-0.0177S0
G1X-0.0141S127.5
G1X-0.0263S0
G1X-0.0149S127.5
G1X-0.0264S0
G1X-0.0145S127.5
G1X-0.0427S0
G1X-0.0148S127.5
G1X-0.0149S0
G1X-0.015S127.5
G1X-0.0468S0
G1X-0.0151S127.5
G1X-0.0146S0
G1X-0.0151S127.5
G1X-0.0467S0
G1X-0.0152S127.5
G1X-0.0153S0
G1X-0.0134S127.5
G1X-0.0199S0
G1X-0.0133S127.5
G1X-0.0049S0
G1X-0.0123S127.5
G1X-0.02S0
G1X-0.0141S127.5
G1X-0.0833S0
G1X-0.0038Y0.0125S0
G1X0.0833S0
G1X0.0144S127.5
G1X0.027S0
G1X0.0238S127.5
G1X0.0268S0
G1X0.0137S127.5
G1X0.0159S0
G1X0.0173S127.5
G1X0.0333S0
G1X0.0171S127.5
G1X0.0238S0
G1X0.0173S127.5
G1X0.0333S0
G1X0.017S127.5
G1X0.0238S0
G1X0.0164S127.5
G1X0.031S0
G1X0.0205S127.5
G1X0.0216S0
G1X0.0152S127.5
G1X0.0354S0
G1X0.0142S127.5
G1X0.0174S0
G1X0.0173S127.5
G1X0.0333S0
G1X0.0174S127.5
G1X0.0228S0
G1X0.0144S127.5
G1X0.04S0
G1X0.0143S127.5
G1X0.0228S0
G1X0.0144S127.5
G1X0.022S0
G1X0.0143S127.5
G1X0.0217S0
G1X0.0143S127.5
G1X0.0171S0
G1X0.0179S127.5
G1X0.0335S0
G1X0.0169S127.5
G1X0.0334S0
G1X0.0163S127.5
G1X0.0241S0
G1X0.017S127.5
G1X0.0333S0
G1X0.0175S127.5
G1X0.0234S0
G1X0.0207S127.5
G1X0.0303S0
G1X0.0163S127.5
G1X0.0253S0
G1X0.0168S127.5
G1X0.0336S0
G1X0.0162S127.5
G1X0.0706S0
G1X0.0172S127.5
G1X0.0313S0
G1X0.0161S127.5
G1X0.0165S0
G1X0.0173S127.5
G1X0.0333S0
G1X0.0172S127.5
G1X0.0233S0
G1X0.0201S127.5
G1X0.0278S0
G1X0.0223S127.5
G1X0.0277S0
G1X0.0161S127.5
G1X0.0833S0
G1X-0.0065Y0.0125S0
G1X-0.0834S0
G1X-0.037S127.5
G1X-0.0135S0
G1X-0.0373S127.5
G1X-0.0067S0
G1X-0.0129S127.5
G1X-0.035S0
G1X-0.0446S127.5
G1X-0.0381S0
G1X-0.0434S127.5
G1X-0.0926S0
G1X-0.0445S127.5
G1X-0.0436S0
G1X-0.0403S127.5
G1X-0.007S0
G1X-0.0129S127.5
G1X-0.0351S0
G1X-0.0448S127.5
G1X-0.0465S0
G1X-0.0443S127.5
G1X-0.0319S0
G1X-0.0184S127.5
G1X-0.0294S0
G1X-0.0143S127.5
G1X-0.0217S0
G1X-0.0143S127.5
G1X-0.022S0
G1X-0.0144S127.5
G1X-0.0228S0
G1X-0.0143S127.5
G1X-0.04S0
G1X-0.0144S127.5
G1X-0.0341S0
G1X-0.045S127.5
G1X-0.0245S0
G1X-0.0142S127.5
G1X-0.0445S0
G1X-0.0154S127.5
G1X-0.0169S0
G1X-0.0143S127.5
G1X-0.0048S0
G1X-0.0384S127.5
G1X-0.0452S0
G1X-0.045S127.5
G1X-0.047S0
G1X-0.0446S127.5
G1X-0.0235S0
G1X-0.0138S127.5
G1X-0.0338S0
G1X-0.0172S127.5
G1X-0.0339S0
G1X-0.0147S127.5
G1X-0.0834S0
G1X0.362Y0.0125S0
G1X0.0833S0
G1X0.0143S127.5
G1X0.2861S0
G1X0.0144S127.5
G1X0.058S0
G1X0.0143S127.5
G1X0.0834S0
G1Y0.0125S0
G1X-0.0834S0
G1X-0.0143S127.5
G1X-0.0217S0
G1X-0.0143S127.5
G1X-0.022S0
G1X-0.0144S127.5
G1X-0.2861S0
G1X-0.0143S127.5
G1X-0.0833S0
G1X1.3477Y0.05S0
G1X0.0834S0
G1X0.0168S127.5
G1X0.0834S0
G1X0.0118Y0.0125S0
G1X-0.0834S0
G1X-0.0208S127.5
G1X-0.0034S0
G1X-0.0067S127.5
G1X-0.0833S0
G1X0.0232Y0.0125S0
G1X0.0834S0
G1X0.0136S127.5
G1X0.0833S0
G1X0.0048Y0.0125S0
G1X-0.0833S0
G1X-0.0173S127.5
G1X-0.0571S0
G1X-0.0381S127.5
G1X-0.0054S0
G1X-0.0133S127.5
G1X-0.0784S0
G1X-0.047S127.5
G1X-0.0516S0
G1X-0.0143S127.5
G1X-0.0199S0
G1X-0.015S127.5
G1X-0.009S0
G1X-0.0444S127.5
G1X-0.0298S0
G1X-0.0433S127.5
G1X-0.08S0
G1X-0.0143S127.5
G1X-0.0403S0
G1X-0.0143S127.5
G1X-0.0132S0
G1X-0.0262S127.5
G1X-0.028S0
G1X-0.0143S127.5
G1X-0.0353S0
G1X-0.0176S127.5
G1X-0.0314S0
G1X-0.0177S127.5
G1X-0.0831S0
G1X-0.0134S127.5
G1X-0.0053S0
G1X-0.0384S127.5
G1X-0.0446S0
G1X-0.0462S127.5
G1X-0.025S0
G1X-0.0263S127.5
G1X-0.0361S0
G1X-0.0143S127.5
G1X-0.0235S0
G1X-0.015S127.5
G1X-0.0088S0
G1X-0.0446S127.5
G1X-0.0429S0
G1X-0.0143S127.5
G1X-0.0266S0
G1X-0.0431S127.5
G1X-0.0801S0
G1X-0.0143S127.5
G1X-0.0358S0
G1X-0.0143S127.5
G1X-0.036S0
G1X-0.0144S127.5
G1X-0.0342S0
G1X-0.0461S127.5
G1X-0.0243S0
G1X-0.0262S127.5
G1X-0.0348S0
G1X-0.0476S127.5
G1X-0.0289S0
G1X-0.0129S127.5
G1X-0.0075S0
G1X-0.0394S127.5
G1X-0.0487S0
G1X-0.0539S127.5
G1X-0.0833S0
G1X-0.014Y0.0125S0
G1X0.0833S0
G1X0.0213S127.5
G1X0.0395S0
G1X0.0215S127.5
G1X0.0267S0
G1X0.0167S127.5
G1X0.0301S0
G1X0.0206S127.5
G1X0.0197S0
G1X0.0165S127.5
G1X0.0346S0
G1X0.0155S127.5
G1X0.0214S0
G1X0.0147S127.5
G1X0.0284S0
G1X0.0172S127.5
G1X0.0339S0
G1X0.0174S127.5
G1X0.0228S0
G1X0.0144S127.5
G1X0.036S0
G1X0.0143S127.5
G1X0.0358S0
G1X0.0143S127.5
G1X0.0692S0
G1X0.0167S127.5
G1X0.0322S0
G1X0.0157S127.5
G1X0.016S0
G1X0.0143S127.5
G1X0.0357S0
G1X0.0162S127.5
G1X0.0355S0
G1X0.0215S127.5
G1X0.0259S0
G1X0.0143S127.5
G1X0.0324S0
G1X0.0148S127.5
G1X0.0289S0
G1X0.0175S127.5
G1X0.0338S0
G1X0.0176S127.5
G1X0.0226S0
G1X0.0165S127.5
G1X0.0312S0
G1X0.02S127.5
G1X0.0793S0
G1X0.0248S127.5
G1X0.0248S0
G1X0.0249S127.5
G1X0.0313S0
G1X0.0143S127.5
G1X0.0243S0
G1X0.0148S127.5
G1X0.0283S0
G1X0.0143S127.5
G1X0.0403S0
G1X0.0143S127.5
G1X0.0691S0
G1X0.0167S127.5
G1X0.0323S0
G1X0.0157S127.5
G1X0.012S0
G1X0.0162S127.5
G1X0.0357S0
G1X0.0213S127.5
G1X0.0224S0
G1X0.0143S127.5
G1X0.0404S0
G1X0.0177S127.5
G1X0.0341S0
G1X0.0171S127.5
G1X0.0677S0
G1X0.0202S127.5
G1X0.0311S0
G1X0.0163S127.5
G1X0.0415S0
G1X0.0133S127.5
G1X0.0007S0
G1X0.0127S127.5
G1X0.0834S0
G1X0.0046Y0.0125S0
G1X-0.0833S0
G1X-0.0138S127.5
G1X-0.0081S0
G1X-0.0143S127.5
G1X-0.0323S0
G1X-0.0148S127.5
G1X-0.043S0
G1X-0.0142S127.5
G1X-0.1257S0
G1X-0.0152S127.5
G1X-0.0361S0
G1X-0.0143S127.5
G1X-0.0227S0
G1X-0.015S127.5
G1X-0.041S0
G1X-0.0161S127.5
G1X-0.0123S0
G1X-0.0109S127.5
G1X-0.0433S0
G1X-0.0149S127.5
G1X-0.0652S0
G1X-0.0143S127.5
G1X-0.0403S0
G1X-0.0143S127.5
G1X-0.0289S0
G1X-0.0143S127.5
G1X-0.0242S0
G1X-0.0143S127.5
G1X-0.0274S0
G1X-0.0131S127.5
G1X-0.0057S0
G1X-0.0133S127.5
G1X-0.0182S0
G1X-0.0124S127.5
G1X-0.0063S0
G1X-0.0132S127.5
G1X-0.0755S0
G1X-0.0146S127.5
G1X-0.0425S0
G1X-0.015S127.5
G1X-0.0763S0
G1X-0.0151S127.5
G1X-0.0252S0
G1X-0.0143S127.5
G1X-0.0323S0
G1X-0.0143S127.5
G1X-0.0263S0
G1X-0.0152S127.5
G1X-0.0408S0
G1X-0.0162S127.5
G1X-0.0363S0
G1X-0.0143S127.5
G1X-0.0156S0
G1X-0.0109S127.5
G1X-0.0432S0
G1X-0.0149S127.5
G1X-0.0652S0
G1X-0.0143S127.5
G1X-0.0358S0
G1X-0.0143S127.5
G1X-0.036S0
G1X-0.0144S127.5
G1X-0.0185S0
G1X-0.0154S127.5
G1X-0.0467S0
G1X-0.0149S127.5
G1X-0.0248S0
G1X-0.0143S127.5
G1X-0.0205S0
G1X-0.0166S127.5
G1X-0.0704S0
G1X-0.0147S127.5
G1X-0.0395S0
G1X-0.0145S127.5
G1X-0.0191S0
G1X-0.0169S127.5
G1X-0.0617S0
G1X-0.0166S127.5
G1X-0.0833S0
G1X-0.0039Y0.0125S0
G1X0.0834S0
G1X0.0158S127.5
G1X0.1023S0
G1X0.0143S127.5
G1X0.0399S0
G1X0.0145S127.5
G1X0.0336S0
G1X0.0454S127.5
G1X0.0285S0
G1X0.0143S127.5
G1X0.0234S0
G1X0.0148S127.5
G1X0.0499S0
G1X0.0147S127.5
G1X0.0175S0
G1X0.0144S127.5
G1X0.036S0
G1X0.0143S127.5
G1X0.0358S0
G1X0.0143S127.5
G1X0.0641S0
G1X0.0144S127.5
G1X0.0713S0
G1X0.0143S127.5
G1X0.0458S0
G1X0.0469S127.5
G1X0.0013S0
G1X0.0145S127.5
G1X0.0263S0
G1X0.0143S127.5
G1X0.0323S0
G1X0.0143S127.5
G1X0.0241S0
G1X0.078S127.5
G1X0.013S0
G1X0.0148S127.5
G1X0.0457S0
G1X0.0131S127.5
G1X0.0717S0
G1X0.0135S127.5
G1X0.0131S0
G1X0.0123S127.5
G1X0.0117S0
G1X0.0133S127.5
G1X0.0127S0
G1X0.0133S127.5
G1X0.0235S0
G1X0.0143S127.5
G1X0.0242S0
G1X0.0143S127.5
G1X0.0289S0
G1X0.0143S127.5
G1X0.0403S0
G1X0.0143S127.5
G1X0.064S0
G1X0.0147S127.5
G1X0.0772S0
G1X0.0469S127.5
G1X0.0013S0
G1X0.0145S127.5
G1X0.0228S0
G1X0.0143S127.5
G1X0.035S0
G1X0.078S127.5
G1X0.064S0
G1X0.0132S127.5
G1X0.0457S0
G1X0.0146S127.5
G1X0.0261S0
G1X0.0147S127.5
G1X0.0168S0
G1X0.0141S127.5
G1X0.0833S0
G1X0.0047Y0.0125S0
G1X-0.0834S0
G1X-0.0141S127.5
G1X-0.0259S0
G1X-0.015S127.5
G1X-0.0223S0
G1X-0.0151S127.5
G1X-0.0427S0
G1X-0.0147S127.5
G1X-0.0652S0
G1X-0.0146S127.5
G1X-0.046S0
G1X-0.0149S127.5
G1X-0.0353S0
G1X-0.0153S127.5
G1X-0.0228S0
G1X-0.0146S127.5
G1X-0.124S0
G1X-0.015S127.5
G1X-0.065S0
G1X-0.0144S127.5
G1X-0.0397S0
G1X-0.0148S127.5
G1X-0.0289S0
G1X-0.0143S127.5
G1X-0.0242S0
G1X-0.0143S127.5
G1X-0.0196S0
G1X-0.0135S127.5
G1X-0.0197S0
G1X-0.0132S127.5
G1X-0.0052S0
G1X-0.0123S127.5
G1X-0.0198S0
G1X-0.0139S127.5
G1X-0.0679S0
G1X-0.0148S127.5
G1X-0.0425S0
G1X-0.0151S127.5
G1X-0.0153S0
G1X-0.0148S127.5
G1X-0.046S0
G1X-0.0149S127.5
G1X-0.0253S0
G1X-0.0143S127.5
G1X-0.0323S0
G1X-0.0143S127.5
G1X-0.0263S0
G1X-0.0145S127.5
G1X-0.093S0
G1X-0.0153S127.5
G1X-0.0698S0
G1X-0.015S127.5
G1X-0.065S0
G1X-0.0143S127.5
G1X-0.0353S0
G1X-0.0148S127.5
G1X-0.0352S0
G1X-0.0152S127.5
G1X-0.0186S0
G1X-0.015S127.5
G1X-0.0471S0
G1X-0.0149S127.5
G1X-0.0247S0
G1X-0.0143S127.5
G1X-0.0653S0
G1X-0.0208S127.5
G1X-0.0214S0
G1X-0.0145S127.5
G1X-0.0399S0
G1X-0.0143S127.5
G1X-0.1039S0
G1X-0.016S127.5
G1X-0.0833S0
G1X0.0003Y0.0125S0
G1X0.0833S0
G1X0.0161S127.5
G1X0.1035S0
G1X0.0143S127.5
G1X0.0399S0
G1X0.0145S127.5
G1X0.0206S0
G1X0.0139S127.5
G1X0.0338S0
G1X0.0152S127.5
G1X0.024S0
G1X0.0143S127.5
G1X0.0289S0
G1X0.0173S127.5
G1X0.0342S0
G1X0.0172S127.5
G1X0.0227S0
G1X0.02S127.5
G1X0.0282S0
G1X0.022S127.5
G1X0.0279S0
G1X0.016S127.5
G1X0.0699S0
G1X0.0168S127.5
G1X0.0324S0
G1X0.0156S127.5
G1X0.0158S0
G1X0.0203S127.5
G1X0.0335S0
G1X0.0158S127.5
G1X0.0366S0
G1X0.0159S127.5
G1X0.027S0
G1X0.0143S127.5
G1X0.0323S0
G1X0.0143S127.5
G1X0.0297S0
G1X0.0165S127.5
G1X0.0347S0
G1X0.0158S127.5
G1X0.0236S0
G1X0.0164S127.5
G1X0.0315S0
G1X0.0205S127.5
G1X0.0641S0
G1X0.0142S127.5
G1X0.0268S0
G1X0.024S127.5
G1X0.0266S0
G1X0.0137S127.5
G1X0.0157S0
G1X0.0143S127.5
G1X0.0242S0
G1X0.0143S127.5
G1X0.0289S0
G1X0.0201S127.5
G1X0.0314S0
G1X0.0161S127.5
G1X0.0703S0
G1X0.0171S127.5
G1X0.0322S0
G1X0.0158S127.5
G1X0.0156S0
G1X0.0159S127.5
G1X0.0365S0
G1X0.0159S127.5
G1X0.0234S0
G1X0.0203S127.5
G1X0.0347S0
G1X0.0164S127.5
G1X0.0348S0
G1X0.0159S127.5
G1X0.0692S0
G1X0.0204S127.5
G1X0.0315S0
G1X0.0165S127.5
G1X0.0217S0
G1X0.0152S127.5
G1X0.035S0
G1X0.0142S127.5
G1X0.0833S0
G1X0.0047Y0.0125S0
G1X-0.0833S0
G1X-0.0143S127.5
G1X-0.0441S0
G1X-0.0155S127.5
G1X-0.0268S0
G1X-0.0399S127.5
G1X-0.0043S0
G1X-0.0143S127.5
G1X-0.0799S0
G1X-0.0455S127.5
G1X-0.0207S0
G1X-0.027S127.5
G1X-0.0053S0
G1X-0.0129S127.5
G1X-0.0302S0
G1X-0.0523S127.5
G1X-0.0344S0
G1X-0.0447S127.5
G1X-0.0884S0
G1X-0.0412S127.5
G1X-0.0048S0
G1X-0.0143S127.5
G1X-0.0145S0
G1X-0.0392S127.5
G1X-0.0137S0
G1X-0.0143S127.5
G1X-0.0117S0
G1X-0.0139S127.5
G1X-0.0335S0
G1X-0.0175S127.5
G1X-0.0336S0
G1X-0.0147S127.5
G1X-0.0602S0
G1X-0.0143S127.5
G1X-0.0043S0
G1X-0.0401S127.5
G1X-0.0438S0
G1X-0.0456S127.5
G1X-0.0262S0
G1X-0.0392S127.5
G1X-0.0052S0
G1X-0.0436S127.5
G1X-0.0211S0
G1X-0.0523S127.5
G1X-0.0178S0
G1X-0.0269S127.5
G1X-0.0053S0
G1X-0.013S127.5
G1X-0.0254S0
G1X-0.0444S127.5
G1X-0.0868S0
G1X-0.0382S127.5
G1X-0.0125S0
G1X-0.0384S127.5
G1X-0.006S0
G1X-0.0129S127.5
G1X-0.0337S0
G1X-0.0466S127.5
G1X-0.0255S0
G1X-0.0394S127.5
G1X-0.0212S0
G1X-0.0474S127.5
G1X-0.0283S0
G1X-0.0145S127.5
G1X-0.0399S0
G1X-0.0143S127.5
G1X-0.1009S0
G1X-0.0166S127.5
G1X-0.0833S0
G1X0.0052Y0.0125S0
G1X0.0833S0
G1X0.0176S127.5
G1X0.0559S0
G1X0.0176S127.5
G1X0.1974S0
G1X0.0143S127.5
G1X0.5339S0
G1X0.0144S127.5
G1X0.0323S0
G1X0.0143S127.5
G1X0.1744S0
G1X0.0143S127.5
G1X0.2236S0
G1X0.0143S127.5
G1X0.0289S0
G1X0.0143S127.5
G1X0.4873S0
G1X0.0143S127.5
G1X0.0834S0
G1Y0.0125S0
G1X-0.0834S0
G1X-0.0143S127.5
G1X-0.4873S0
G1X-0.0143S127.5
G1X-0.0289S0
G1X-0.0143S127.5
G1X-0.0242S0
G1X-0.0143S127.5
G1X-0.1851S0
G1X-0.0143S127.5
G1X-0.1744S0
G1X-0.0143S127.5
G1X-0.026S0
G1X-0.0194S127.5
G1X-0.5352S0
G1X-0.0143S127.5
G1X-0.2056S0
G1X-0.0271S127.5
G1X-0.0181S0
G1X-0.0282S127.5
G1X-0.0833S0
G1X0.0235Y0.0125S0
G1X0.0833S0
G1X0.0289S127.5
G1X0.7875S0
G1X0.0242S127.5
G1X0.0833S0
; Cut @ 200.0001 in/min, 50% power
M9
G0X-1.006Y0.056
; Layer C00
G1X2.0971S127.5
G1Y-0.4276
G1X-2.0971
G1Y0.4276
M9
G1S0
M5
; return to starting pos
G0 X0Y-0.4276
M2
G1 S0 sets the laser power to 0 percent
M5 is “laser off”.
Then it goes back to the starting point and ends the job. The gcode is correct.
Sevvn
(Shawn Yates)
November 13, 2020, 2:10am
12
What does the fire laser button send?
M3, G1 Sxxx, and then M5 when you shut it off.
Sevvn
(Shawn Yates)
November 19, 2020, 1:31pm
14
I found the issue and thought I would share it here incase anyone else hits this odd little problem.
It was a wiring problem like Oz said.
The wire plug that came with the JTECH laser has part of the metal pin exposed on the plastic housing. This is common actually, but with the orientation and location that the connector plugged onto the Shapeoko mother board, the exposed metal pins would make contact with the adjacent unused pins on the header.
To fix this I simply reversed the wires so that the exposed metal part faced away from the adjacent row of pins!
What let me to this was a secondary symptom found during trouble shooting. Connecting the wiring harness to the Shapeoko MB would sometimes cause the Shapeoko to stop responding to the computer. Even when only one only the Shapeoko side of the wire was plugged in. This nailed down that the problem was the physical wire itself.
I ohmed out the wire harness several times and found no shorts. After that I noticed the exposed metal and the orientation and there it was!
I hope this helps someone else someday!
system
(system)
Closed
December 19, 2020, 1:31pm
15
