Hey guys, having an black and red China 80Watts machine. I changed the Leetro to a Ruida 6445G. All worked fine. And while testing some different Speed/Power settings the Laser now doesn’t fire from one cut to the other.
So it worked, I changed Speed, no Fire
Changed the Speed back, still no Fire.
Off/On, nothing.
When I press the Pulse button it fires.
So what can that be ? Water Protect is on and works, otherwise it wouldn’t pulse, right ?!
Ruida controllers use active-low for the L-ON signal, and some other systems (TopWisdom, for example) use active-high, so if you’re connected to the L input on the power supply that’s likely ok, but if you’re connected to the H input it might not be.
No, I‘m connected to the L.
Like I said, it worked just fine, I did not change anything. I engraved one square, changed the speed and power, nothing.
Changed it back… nothing.
Power down and up again, nothing…
The Min Power setting on the Ruida panel itself doesn’t matter. The one in the cut setting matters a great deal - if it’s too low, the tube won’t fire.
Once you get it straightened out, make a back up of your Vendor Settings. If you ever make a change and can’t get working, you can reload your back up and be back in business.
