# Laser Stops about 1/3 way through a job
**URL:** <https://forum.lightburnsoftware.com/t/laser-stops-about-1-3-way-through-a-job/43761>\
**Created:** [July 7, 2021, 5:37pm UTC](https://forum.lightburnsoftware.com/t/laser-stops-about-1-3-way-through-a-job/43761 "2021-07-07T17:37:16Z")\
**Showing post:** 2
**Author:** ![Rick](https://forum.lightburnsoftware.com/user_avatar/forum.lightburnsoftware.com/rick/32/69_2.png) [@Rick](https://forum.lightburnsoftware.com/u/Rick)\
**Post date:** [July 7, 2021, 7:16pm UTC](https://forum.lightburnsoftware.com/t/laser-stops-about-1-3-way-through-a-job/43761/2 "2021-07-07T19:16:27Z")
> [@ORTUR LASER MASTER 2 - Service Notice - Grounding](https://forum.lightburnsoftware.com/t/ortur-laser-master-2-service-notice-grounding/34066):
> ORTUR LASER MASTER 2 - Service Notice - Grounding Full Documentation: [http://ortur.tech/orturgrounding](http://ortur.tech/orturgrounding?fbclid=IwAR0F--qTZ2AlNDfC_YaqfHC8s2LOM2IQe6hAw2m5aHgXNhbKJXuJiHhK7l0) Some users have been reporting and experiencing Static Electricity build up in their machines while in use, especially on raster engraving operations. This build up of Static Electricity can become severe to the point that its discharge – via the 12v rail – can cause the motherboard to reset. Therefore causing interrupted engraving operations (Alarm 3/Connection Lost errors). In extreme cir…
> [@ORTUR LASER MASTER series v1.4 Firmware Release](https://forum.lightburnsoftware.com/t/ortur-laser-master-series-v1-4-firmware-release/30442):
> WINDOWS Computers ONLY - Do not Attempt on MAC/LINUX Change Log: V1.40 Release Date: 04 January 2021 Fixes: Pause/Resume issue been corrected. Laser Pause/Resume functions now work as expected; Corrected False positive [Check Limits] on Pro Motherboards (RJ connector/Vertical buttons boards); Improvements: GRBL Core Upgrade from 1.1f to 1.1h; Optimization of USB Driver Library. Attempt to address disconect issues/Alarm 3; Fan Delay ShutDown Function. Fan will Remain on from 30 to 120 sec…
_[View the full topic](https://forum.lightburnsoftware.com/t/laser-stops-about-1-3-way-through-a-job/43761)._
