Laser stops - Connection lost
I’m engraving and cutting an ornament. I just fixed the “homing cycle is not enabled in your Grbl settings” problem by shutting off “auto home your laser on startup”. Since then my laser stops at around 60% or so. It engraves and cuts the inner elements fine but when it starts the outer circle it stops. Here is the code I get. Any help fixing this would be appreciated
Connection lost
Stream completed in 9:22
error:7
EEPROM read failed. Reset and restored to default values.
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=0
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$100=80.000
$101=80.000
$102=250.000
$110=6000.000
$111=6000.000
$112=1000.000
$120=1000.000
$121=1000.000
$122=10.000
$130=410.000
$131=400.000
$132=200.000
Grbl 1.1f [’$’ for help]
ok
[VER:1.1f.20170801:]
[OPT:VI,15,128]
Target buffer size found
ok
The error is “connection lost” - the USB connection to the controller drops.
Read here for some common causes and solutions:
https://lightburnsoftware.github.io/NewDocs/Troubleshooting-Connection.html
