I have a NEJE Max 4 20 W diode laser, runs GRBL. Lightburn is 2.0.01. I’ve had my laser for about 3 years and this has always been an issue but it’s getting worse. Today I got my first actual error message. Prior to that, it would just stop. Laser temp didn’t seem to be a factor as it would stop at 30C and 50C. I thought I was sending too large of a file so I broke it down. But even a 1min score job gets stopped, even if the laser hasn’t been running. It wouldn’t always stop the laser beam, it would just stop moving. Then I would press the “stop” button in lightburn and it would act like it was stopping but LB would show the laser as “busy” and I would need to disconnect my USB from my computer, wait for it to show “disconnected” then reconnect.
today I got the error message in my console “hold by laser overheat, resume by press key”. Even with that message, sometimes the beam stays on and I need to disconnect and reconnect. At this point I’ve tried so many things and I’m not sure if it’s a LB issue or a laser issue.
I would look at your laser module first. Fan working? Blow out any dirt and dust, clean the lens protector and see if that helps.
Same opinion here. When you blow out the dust, make sure the cooling fan cannot spin. It can generate enough voltage to cook the electronics.
I had to take both of my laser modules apart to clean them properly. Be sure to cover the nozzle with tape so you do not blow or flush dirt into that part.
thanks. I cleaned it a few weeks ago (I don’t use it that much) but I’ll clean it again
did a deep clean, still happening. no warning, no error in the console. laser temp 45C
Any chance you installed the fan upside down and then put it in the same way again? It should be blowing air into the module.
EDIT:
Maybe it is the controller board and not the laser module.
Try LaserGRBL like @Dskall suggeated.
Next I would download lasergrbl and see if it works there.
I tried beam bench and it wouldn’t even stay connected to send the file
nope, the fans are blowing the correct way. I also have a huge shop fan blowing across the laser/laser bed.
I tried beam bench and it didn’t work either.
I sent a file this morning that was a 30 min runtime. score and 2 cut layers. score completed. 1st cut layer stopped part way through, no error message, no high temp warning. stopped the job, had to disconnect and reconnect the laser from the computer, sent it to origin and sent the 1st cut layer. Cut completed. sent 2nd cut layer, cut completed but stopped on the way back to the finish position with a high temp warning. sent a new file to cut, cut completed but stopped on the way back to the finish position. no error, no warning showed it was still running on LB. Had to disconnect and reconnect the laser from my laptop again. sent it to home and turned it off. lol Luckily I am done for the day.
Have you turned off the USB Energy Saver in Windows?
yes I have turn off the USB energy saver. I unchecked the box that says “let computer manage the power” or whatever it was lol inside device manager. My computer power settings are set to never turn off the hard drive
Probably not laser module, not Lightburn software, so maybe bad USB cable, bad electrical connection or possible firmware/controller problem.
My first machine build did all kinds of weird things. Being new to this I didn’t know if I was causing the problem. I bought another controller and programed it and haven’t had issue since.
I’ve tried multiple USB 2.0 cables. Same problem with all of them. Firmware is UTD. Rewiring/soldering is out of my scope. I think I’ve exhausted all logical reasons it is doing this. Gotta be a motherboard/controller board issue at this point.
I would try running it and wiggling all connections first.
