While running a job my laser stops at a certain point each time. If I rearrange the order in which each layer is cut, it still stops after a short while. Anyone have an idea of what’s causing this?
what error does your console display when it stops?
There is no error. Consol says stream complete 16 seconds
The problem you have is your laser bed size is not set correctly. You need to reinstall the device as new in devices and delete the old one. If it is doing this while using the rotary then the issue is the rotary is running out of x or y travel. Feel free to call me (Redacted by mods)
No error showing up.
Gatorman, thanks - I’ll try doing that.
