I have had my Ortur LM2 Pro SF for 10 months, I installed the Ortur 10 watt module last month. Today it started to “Stop Firing” in the same spot each time. The laser keeps running, but it stops firing. If I start the program over, it stops at the same spot. If I use the “Review Window” and start it from the spot where it turned off, if will fire and them stop in about a second or two. Any Suggestions?
$RST=* resets your controller to its GRBL defaults
If you type $RST=* in your console window, (making sure the connection state is NOT busy) the controller will reset to defaults.
