drew a simple hexagon 4"x4" , laser cuts 5 of the 6 sides then stops ??
recently installed limit switches on my 3018 pro which has aprox 300x180 work area. configured grbl and homing sequence works fine .
z goes all wall up , hits switch then comes back down a bit
then x moves to far left and y axis table moves to back and triggers that limit switch so home is bottom left 0:0:0 .
i tried moving drawing around pallet but still wont finish ??
tried a simple circle and laser starts and moves for a few seconds then stops . no error codes??
Are you running the job in ‘Absolute Coords’ mode? Or one of the others?
If you’re using a different mode, you might be too close to the starting position and triggering a limit when it gets to the end. Does the console say anything? (You can copy & paste the console output here for us to look at)
After you save the file from LightBurn, you should be able to open it with any text editor. You may need to change the file extension to “.txt” to open, but the file LightBurn generates is a simple ASCII text file.
