I’ve seen a post on the matter, but I’m still confused…
I have no problem setting up my engraving speed, the issue is when the laser moves on from one shape to another, it goes way too fast (I bet i makes my support vibrate and my material move slightly).
Where do I slow down that travel speed (shift speed?).
That would be the firmware settings that you would need to adjust from what you currently have set.
More specifics will require current setting to be shared.
Thanks Rick! Just changed the X and Y max rates and accelerations.
I guess it’ll also go easier or the wear and tear. For those interested, here is the table to modify:
