Laser unable to find x-0,y-0
Since I removed my 20 watt Laser replacing it with a 40 watt laser, my tool pro is in able to locate zero. Retuning to home it try’s to go to x-0 rattles when it goes all the way left then goes up to y-0 rattles for a few seconds then stops.
This only happens with LightBurn and not with other software.
If I go back to the 20 watt it operates correctly.
Does the machine home correctly with the 40W laser?
If no, then find out what’s physically impeding the laser from homing.
If yes, then have you adjusted the pointer offset in Edit->Device Settings to account for the differences in the two modules?
For the 40W it should be X0, Y-21.
Thanks for replying, nothing is holding it to Zero and yes, my settings are X=0 Y= -21
I even tried to move the limits with no luck.
This is almost certainly something physical/mechanical if the machine otherwise homes correctly with the 20W laser.
Can you clearly see that the homing sensors are able to be reached with the 40W installed. Check discretely for both X and Y.
What happened when you did this?
