[MSG:Warning: Flame Sensor Disabled by User OverRide]
[MSG:Flame detector active,Ambient infrared value:0]
Grbl 1.1f [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
Here is an update
Starting stream
Layer C01 Pass 1 of 3
Layer C01 Pass 2 of 3
Layer C01 Pass 3 of 3
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 5:
Stream completed in 0:01
[MSG:Reset to continue]
ok
Ortur Laser Master 2 Pro S2 Ready!
OLF:OLF 191.
OLH:OLM_ESP_PRO_V1.2.
OLM:GENERAL.
ok
$0=5.0
$1=100
$2=0
$3=2
$4=7
$5=7
$6=1
$10=2047
$11=0.050
$12=0.002
$13=0
$14=6
$15=0
$16=1
$17=4
$18=0
$19=0
$20=1
$21=1
$22=1
$23=7
$24=600.000
$25=3000.000
$26=100
$27=3.000
$28=0.100
$29=0.0
$30=1000.
$31=0.
$32=1
$33=1000.000
$34=0.000
$35=0.000
$36=100.000
$37=0
$39=1
$40=1
$41=0
$42=1
$43=1
$44=3
$45=0
$46=0
$56=1.000
$57=1800.000
$58=395.000
$59=6000.000
$60=0
$61=0
$62=0
$63=3
$64=1
$65=0
$100=80.000
$101=80.000
$102=2124.000
$110=10200.000
$111=10200.000
$112=600.000
$120=2200.000
$121=1800.000
$122=200.000
$130=400.000
$131=400.000
$132=100.000
$259=0
$260=70
$261=0
$262=750
$263=0
$264=0
$265=50
$266=100
$267=0
$268=0
$269=0
$270=5120
ok
Please review this post. Check the conditions that you should meet listed in the post. If this doesn’t address the issue then indicate what you’re attempting to do, what you’re expecting to happen, and what’s happening instead.
I meet all those conditions listed. My laser was working great until this last simple sign burn. I did not have the power high enough for the burn I needed. I adjusted the power (to the normal power I use for that wood and have done a hundred times). I rehomed and clicked start but it gave me the above message. I updated firmware, RST=*, and nothing has changed.
Can you upload the .lbrn file that caused the issue?
You are using “User Origin” as the Start From mode in Laser Window. Is that deliberate? If not, what happens if you change it to Absolute Coords?
That was me trying to mess with it after it stopped working. It wont work either way. Still get the same error
Can you run these commands in Console and return the full output:
$H
Also, please take a full screenshot of LightBurn with your design loaded and ready to burn.
