Laser Will Not Finish - KentokTool JL5
Hello, I am new to this and any help is greatly appreciated. Whenever I try to engrave / cut, my laser comes on, cuts the first “section” i.e. the first letter or square, then even though it continues to track the rest of the design like its engraving/cutting, the laser shuts off only cutting the first object. I had this happen using the GRBL software and the Light Burn. Laser: Kentol JL5 Computer: Windows 11
Questions
When you added your machine to lightburn you used the automatic detection or you manually added it in?
I would recomend importing the profile from their website
https://cdn.shopify.com/s/files/1/0560/6008/4267/files/Kentoktool_JL5_Lightburn_Configuration.lbdev?v=1702526493
Download the latter link → go to devices → IMport → select the file
Then try something simple again?
Also in console window type $i press enter
And copy/paste the output here please?
I automatically detected. Not sure how to manually add.
This is the output when I typed $i
Waiting for connection…
ok
[VER:TL-L5V2.0.8.046.3]
[MSG:Using machine:Kentoktool_JL5]
[MSG:UID:59323638FF0A5031FFFF2BA4]
ok
Homing
ok
ok
$i
ok
I am looking for the devices IMport but do not see it. I did find the import prefs under the file heading, but when I try to import the file it does not recognize the ext .ibdev. sorry to be such a newbie but i appreciate the help. A little more info, when I ran the LightBurn Interval test, everything printed fine, but when I tried the GRBL cutting test, it only did the first box but while continuing to trace, the laser shut off.
I was in a rush earlier and missed the devices setting but now found it. I updated as you mentioned and seems to working ok now. Thank you so much. I appreciate your help!
Fantastic! For future reference and maybe others
Could you post a Edit → Device setting sscreen shot just so we can peak?
