Hi Guys,
I have an Ender 5 Using the Marlin thingy. It moves around no problem. However the laser will not turn on. I can control the laser using the manual fan speed control on the printer itself. I have tried adjusting the tool index from 0-6 none work. (Not sure what that was. But I read it on someone else questions)
Cheers
start
echo: External Reset
Marlin 1.1.6.1
echo: Last Updated: 2018-11-28 | Author: (Ender-5)
“Using the Marlin thingy” - That’s a new way of wording it.
I have tested LightBurn with versions of Marlin from 1.1.9 and up, but I haven’t tried 1.1.6. You would need to find out what gcode command is required to turn on / off your fan. From that I can tell you if / how you can configure LightBurn to control it.
Hey thank you for that. Not sure how to find that out. Is there away to get into the software? Or send a code manually to see what happens? Thanks again.
You can send codes through the console in LightBurn. There should be some way to save gcode from whatever software you run the printer with to see what turns the fan on now, or consult the documentation for it to see what pin the fan is connected to. I know very little about Marlin myself, and less about Ender printers - sorry.
LightBurn itself emits M106 and M107 commands to turn on / off the laser, unless you’ve changed that in the device settings. Check there to start with. Lower-right in the image below:
You can also make a simple shape like a rectangle, and then click ‘Save GCode’ to see the code that LightBurn would send the laser. You can just type those commands into the console to see what they do, if they work, etc.
