I have an Ortur Laser Master setup running Lightburn, and the setup works nicely for my occasional needs for laser marking on black-anodized aluminum. I noticed today, and I think this is the first time I have seen this over about a half-dozen runs of parts, that the program timer in the Laser window (located in the Disconnected/Connected/Busy bar) is showing a consistent time for the program run for the part at 0:00 (1:22) start, and right about 50% on the progress bar the time has incremented to 1:22(0:00), the the (x.xx) values begin to increment in negative direction until program has completed at 2:15 (-0.53).
I have seen this part run before (didn’t see this behavior), and know that the run time is indeed about 3 minutes+ timed with stopwatch on iPhone, and my question is about how the timer is set up by the software and/or the laser firmware. I also note that when the system hits 99% it is still performing about 13 more seconds, hanging at 99%, before completing and heading for Home. Any ideas about what’s happening here? The part comes out fine.
The percentage is not linear. It’s about the gcode lines and not the time. Imagine a sketch with a short line and then a circle that goes around your full workspace. After the laser finished the small line, it moves to 50%, though the second object will take much longer.
If the time does not fit, either the simulation is incorrect (read the parameters in device settings) or your settings do not meet reality. You might send speeds the laser can’t reach and therefore the predicted time is wrong.
The time at the bottom of the screen goes negative when the computed time is less than the actual run time. It has always been like this. As @misken has pointed out, you need to adjust the Additional Settings in the Device Settings window. Cut Speed Scale and Global Speed Scale is where you make the correction for your specific machine. Mine are pretty close with 85% (LB Support suggested they will likely be the same) in both boxes. Of course, you will have to find a happy medium between short and long projects.
