Laser won’t turn on
Hello,
I’m not positive what I have but it’s a CNC with laser. GRBL. MySweety. I have the laser hooked up to what the manual says to do i think. When I turn on the power to the unit I have to hold the laser button to focus the laser. Otherwise no matter what I do I cannot get it to turn on.
The machine moves on the axis when I run the program but the laser doesn’t turn on. I don’t know how to check appropriate speeds or anything. But I’m not even sure if that’s the problem. I attached my machine to help identify it.
I noted that some boards can’t manage some laser cause request Ampere that board can not give, check if this is your issue
Hallo
Hast du mehr Info GRBL Version, Controller, Software. Bilder gehen auch.
Grüße
