Ruida 130 wont accept file. Was working great and now says machine is paused or busy. any help out there
Right-click the ‘Devices’ button to reset communications with the laser.
Worth checking to see if your controller memory might be full. When connected to your laser, you can view this from LightBurn in the ‘Files’ window. Otherwise, you can use the HMI on the laser panel to review and take action as well.
