Laser wont home... please help
ALARM:8
Homing fail. Cycle failed to clear limit switch when pulling off. Try increasing pull-off setting or check wiring.
ok
Ortur Laser Master 2 Pro Ready!
OLF 152.
[MSG: Flame detector active,Ambient infrared value:4089]
Grbl 1.1f [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
please view video for context>>>> https://youtu.be/mveVmj7dFGE
Check that laser is contacting each switch, and there are no obstructions.
If you view the video the machine moves about a few mm then stops.
What corner is it set to home?
Left front
Is this a new laser?
Are your jog controls moving in right direction?
I had a similar problem caused by a loose connection.
GRBL parameter $27, Homing Pull-off, may need a mm or 2 added to it. It looks like the switch is activating, meaning it works, but the pull-off is not enough to open the switch back up.
do you have a LM2pro? anyone? the reason i ask is if i can get the device info from a file from a current working Laser i think it would work?
i might have applied settings from my other laser and cant find a back up…
