The Y-settings (?) has changed somewhere after I tested my Genmitsu rotary roller, but for me the settings seems normal.
When I frame the full bed, it moves 100mm in stead of 200mm. If I try to engrave a circle, the result is elliptical.
I suppose the truble started when I had to change the roller settings for mm/rotation for the Y axis to match one turn of the object.
I have tried to load the device settings again, but with the same result.
What is the problem? Do I have to change some controller settings?
Do anybody have a good solution?
Trond Atle Tveit. Norway
