Hello–I recently moved my laser printer from my home office to my work office. Upon trying to print today, I find that it’s working as expected EXCEPT that the laser doesn’t seem to be firing during print jobs. I did focus the laser; settings were 2800 and 60%, then I tried at 80%. It did a VERY LIGHT print on two short (~5 min) jobs, but now goes through the job motions without the laser coming on at all during print. When I do a test fire, it works fine. I think I adjusted the S-values, but maybe I’m wrong. Advice please!
One clarifiication–it works during test fire when standing still; the laser shuts off when I frame.
Can you input $$ into console and paste. Also what is your s value set to?
If you did not also copy the LightBurn settings, then:
This is what I have for $$:
$0=5.0
$1=100
$2=0
$3=6
$4=7
$5=7
$6=1
$10=2047
$11=0.050
$12=0.002
$13=0
$14=6
$15=0
$16=1
$17=4
$18=0
$19=0
$20=1
$21=1
$22=1
$23=7
$24=600.000
$25=3000.000
$26=100
$27=3.000
$28=0.100
$29=0.0
$30=1000.
$31=0.
$32=1
$33=1000.000
$34=0.000
$35=0.000
$36=100.000
$37=0
$39=1
$40=1
$41=0
$42=1
$43=1
$44=3
$45=0
$46=0
$56=1.000
$57=1800.000
$58=395.000
$59=6000.000
$60=0
$61=0
$62=0
$63=3
$64=1
$65=0
$100=80.000
$101=80.000
$102=2124.000
$110=10200.000
$111=10200.000
$112=600.000
$120=2200.000
$121=1800.000
$122=200.000
$130=400.000
$131=400.000
$132=100.000
$259=0
$260=70
$261=0
$262=150
$263=0
$264=0
$265=50
$266=100
$267=0
$268=0
$269=0
$270=5120
My S-value max is 1000.
Thank you, ednisley! I’m on the same computer, just moved the physical location. I’m wondering if a wire got damaged in the transfer.
Logically nothing setting wise could change by just moving machine. Must be cable. Is yours the one with the cable that plugs in on top of machine?
You might try starting a job and wiggling the cable/connector on laser.
