Hello,I have a Longer Ray5 20w laser with the extended frame… workspace is 800mm x 800mm. its been working flawlessly for over a year. today it seems the workspace is at 400mm x 400mm and I can’t change it. under device settings/ working size it is set to 800mm x 800mm but I get an alarm 2 if my project is outside the 400mm x 400mm’s. is there another setting somewhere that will get it back to 800mm x 800mm?
Did you expand your bed?
$130 $131 settings must match 800 if you did.
Edit > Device settings, what size is set for the bed?
Yes I have extended the bed and thank you for the response, setting $130 and $131 to 800 did the trick… not sure how it got changed/ thanks bud that was quick and easy
