Laserhoved tilbage til udgangspunkt efter flyttning
Jeg har et problem, når man graverer eller skærer, og flytter laserhovedet, hvordan får jeg det tilbage, til start punktet af opgaven
I have a problem when engraving or cutting and moving the laser head, how do I get it back to the starting point of the task?
Hi Carsten, can you tell us which machine/controller you have?
On my Ruida controller I can determine the start and end position directly on the laser machine (Origin).
Try reading this, it will surely help you. Coordinates and Job Origin - LightBurn Documentation
If it is a GRBL controller, you can use Set Finish Position to go anywhere you want.
If you want it to start in the same place every time, use Absolute Coords and read what @bernd.dk posted.
