I updated to the latest patch this morning (21st Nov) and since then I can only get vertical lines from my camera view. Tried closing, uninstalling and still the same problem. My camera was working fine until I did the patch.
Nothing changed in the camera code for this patch release. Double check that your drivers are current on your computer, and that the camera is connected properly with only the cable it came with. (are you using an extension cable at all? - this is a common reason for the camera not working in the way you’re showing)
