Layer cut settings are persisting between projects
Let’s say I use layer 00 in Project A and set the speed/power to 100/100 and save and close it. I open Project B and use layer 00 and set it to 200/200 and save and close it. If I open up Project A, layer 00 will be set to 200/200…from Project B. I don’t want that. I want to be able to save the layer/cut settings in each project. Can I do that?
I’ve never seen this behavior. Saved projects should retain the settings from the original save. Loading other files could affect layers not referenced in the saved project but all existing layers should be preserved.
Do you have sample files where this occurs that you can upload?
I have the same issue. When I buy a file and it comes in with any of the colors I have set, I can’t figure out what I should be doing because it has overriden the files that I bought with my settings for those colors.
