The layers ribbon goes off the bottom in full screen, and when I try to restore down, it just doesn’t work right, and I can’t resize the window at all. So I cannot see it at all. I need this to work on the Slate and do not understand why it doesn’t seem to want to. I hope you have an answer.
This may due to the resolution of your monitor. LightBurn requires a relatively tall vertical resolution (ie more than the common 768 vertical pixels) then that will be too short for default LightBurn layout. In that case I suggest you collapse the 2 pane window layout on the right and convert it to a single pane model.
The display is 1920x1080. Should be sufficient, right?
Yes. I can’t recall the minimum vertical resolution but 1080 should be fine. Can you take a full screenshot of LightBurn?
