Hello,
I am using LB 2.1.02 on an ezcad3 based fiber laser.
I am wanting to put Z axis controls in the main window so I can tinker with settings with out having to go through the options, menu, click,click, click…
If I go to Laser Tools, Device settings, click on “Ports and Laser settings tab” there are buttons for up down and sellect how much each move is in mm.
If I add the MOVE tab to the controls It puts a tab called “MOVE” next to “cuts/Layers” tab.
Unfortunately the move buttons do not do anything when I click on them. The buttons in device settings work fine.
I bounced around various settings trying to determine why but could not find a sollution.
I also found a glitch/bug…
With the “Move” tab selected. Goto laser tools then device settings. then click OK.
At this point the “Move” tab goes away.
If I hit Cancel from laser tools the “Move” tab stays.
Getting the Move tab to function would be nice as that reduces the number of clicks when I am tinkering with settings.
Putting the Z axis up/down buttons on the main screen would be even nicer ![]()
I love LB and even more so with ezcad3 system.
Take Care,
Mike <><
