LB 2.2 RC-1 Bug - Save As
I opened an existing project in the 2.2 RC-1. Since it is a large project with several sheets I created a couple of pages (so I can do one sheet/page) and then went to use ‘Save As…’ to save under a different name. Error Message below:
If I select an existing file I get a different error message:
On LB 2.1.nn both Save As and selecting an existing file to save to work ok.
“Save As” worked properly for me with 2.2-RC-1 on Mac OS 27.0 And I did get the system dialog warning I was about to override an existing file.
You may try changing the Dialogs prefs:
I ran into the same issue as well. Did not have time to diagnose before my trip. Hopefully it is fixed before I get back home. :rofl:
Win11
Just opened an old project, add pages and save without errors.
Using internal Load/Save Dialogs and saving to local disk.
Just tested Win10 here, production and pre-release. Both just fine. Issue at home was on Win11. Testing there is some days away. I knew I should have brought the 2nd PC with me!
Replying to myself as I managed to debug it - turned out to be protected folders within Microsoft OneDrive.:frowning:
OneDrive, Dropbox, iCloud, remote server: These are all recommended that you avoid when running Lightburn. Okay to use them for archival storage, but working files should be on the local drive.
