LB and DSP Controller
Hi guys - First post here…
I have a laser machine working with Trocen DSP - I plan the file externally, load it to my current SW - make the machine file, load it on a stick then download to DSP via the USB stick connector.
My question is - If I get the LB, and follow the same path as above - will the DSP controller follow the wisdom of the LB settings or would it be better to connect the LB via PC and USB/Ethernet connection to get the most out of LB?
Any suggestion/comment will be very much appreciated.
Many thanks
Isaac
It should work fine either way. A direct connection gains you the ability to jog and place artwork a little easier, but everything else that happens as part of prepping the file for the machine will work regardless of whether it’s a live connection or not.
