vozka
(Vozka)
February 1, 2022, 9:35pm
1
Hi,
I am new to laser cutting and at the moment learning with LB. Unfortunately there is something weird happening each start of program.
W10, LB 1.0.06
Does not matter if I start LB by double click on LB icon on desktop or double click on any existing project. Behave always the same.
So I open LB by double click on existing project. focus-calibration.lbrn (22.9 KB)
Wait to LB fully opens with project.
Click File->Save GCode and let it export.
Open result file and there are commands like: M106
But I am sure that I have changed it to “Inline” sometime ago.
If I click OK (nothing change, just click ok)
And regenerate gcode it is ok now, if I click cancel and regenerate it is still with M106
If I click OK and exit program and start again it is again generating M106 but set is Inline
Am I doing something wrong?
Thanks
Vozka
berainlb
(PY)
February 1, 2022, 10:26pm
2
I believe this issue is discussed here:
I noticed a bug in lightburn, when going into the device settings and making the changes (laser control inline), when saving the gcode everything goes fine, but when I close and open LightBurn again, and save the same gcode, without going into the device settings window, the Gcode is saved as M106/M107, instead of using the inline settings I had made.
Therefore it is necessary, whenever you close and open Lightburn, enter the device settings window, and check the laser control Inline option.
A potential workaround. Try plugging in the laser and connect while you do the save gcode.
Else try reverting to an older version of the software.
vozka
(Vozka)
February 2, 2022, 6:21am
3
Thank you, at least I know that it is not on my side. Unfortunately workaround is not usable for me since I do not have cnc next to PC. I am carying in to another room on SD as gcode.
Anyhow thank you and hope it will be fixed soon.
system
(system)
Closed
March 4, 2022, 6:21am
4
