I’ve been using Bluetooth to serial adapter for connection to my grbl machine.
I noticed that if I close LB and open then only it scans the port.
While I would like it to rescan when I select or switch the COM port in Lower right Laser Tab → Devices ->COMxx
Could you confirm if thats the case… meaning LB only scans connection at bootup ?
I feel like you’re leaving out some context. Or at least minimally a problem statement. What problem are you having that you’re asking about port rescan?
Also not sure if you’re using the word “rescan” in a very specific way. But LightBurn will certainly pickup changes in state to the port. For example, with no devices plugged in LightBurn shows no port connections.
However, after plugging in a device more port options will appear in that pulldown. You may need to right-click on Devices to attempt a reconnect.
