I just picked up a Monport GT 100w MOPA laser. 99% of the time when I start LB, goes straight into Framing, with no Layers created. 1% of the time it will go to Ready and all is good. If I restart LB, back to Framing.
I have tried LB on 3 different PC’s and have the same result.
If I install the Monport bslcad software, it works 100%.
I have tried LB 1.7 through to the 2.2rc
I’m working with Monport support, who have been great, but I still have a box that doesn’t work.
Drives & software have been installed / removed multiple times.
I use the LB configuration file supplied by MonPort.
I also tried creating the laser manually, using the markcfg0 file from the USB stick, using the EzCad2 driver
hi just thought id comment as I got a monport gm 60w fibre last week and having exact same problems.
Spent hours changing ports or anything everything and hey presto it will work then defaults back to stuck in framing everytime.
Could i kindly ask how you set up the BSLapp as my crystal driver came corrupted I did find a driver from hans laser if this is even relevant.
I cant use the machine atall as it stands,
kind regards and good luck.
If i come across anything Ill share
Cheers
Lee
Hi Lee
My install process is very simple, crystal driver and then import the LB driver. You can also install the BSL software at the same time. I probably rebooted to make sure the driver was loaded.
I worked with support, who have been super responsive and I guess arrived at a potential solution quickly. They are sending me a new board. It’s coming from China or similar and will be a few weeks. If that fix doiesn’t work 100% I’ll send it back and order another or go for a different make. Under UK law they have once chance to fix and if that doesn’t work, you can refuse the item.
Since the board is on order it has been working 50% of the time. If it starts in framing I push the button to turn part of it off and restart LB.
When I used the BSL software it worked all the time, but I have a LB license and want to use that.
Try the Monport website for the software. If you get stuck I can load mine into a Google Drive and share it with you.
