LB not framing correctly, and Absolute Coords issue
I connected my rotary (for the 1st time) and entered $22=0 to disable homing. It worked perfectly and when finished I removed it, reconnected the Y stepper, entered $22=1 to enable homing and now I have 2 issues.
1- With absolute coordinates set (lower left radio button) and I hit Frame, the laser moves to the back right corner and bottoms out on the frame.
2- With user origin set and I hit Frame, it will frame as if the objects are located in the far left of the work space when in fact the objects are centered in the work space.
Homing works fine
Check that you disabled the rotary as well:
Yes I disabled the rotary after I removed it from the laser. I’ve done a $RST=* to reset and nothing changed. I’ve restarted the laser and Lightburn several times, I’ve tried different files none of which helped.
Problems solved! It was as simple as doing File > Load Prefs Backup, and choose a date that was before the day I installed and used the rotary. Only thing I had to readd were SHX fonts.
The only minor bummer is I have no idea what I did to cause the issues.
You or a corrupt file might have changed the origin setting of the laser. That’s most likely, I think.
