I just quit my 2 LB instances because the computer got quite sluggish so I wanted to reboot it (it’s just a mini-PC after all). However, before I could hit the reboot button, I noticed the CPU load still being at 100% and investigated:
Is there anything I can do to help in debugging this “process stays after closing the program” issue?
Do this, and email or post the stack trace from the hung application’s main thread:
windows, troubleshooting
Darn, I did not expect such a quick response or I would have waited with cleaning up.
I’ll keep an eye open for this issue. I think this may happen regularly, I’ve been rebooting every couple of days. Didn’t think much of it, the hardware in those 100€ PCs is laughable weak… (On the other hand…how do they make a working PC that cheap? )
ntoskrnl.exe!KeSynchronizeExecution+0x5b66
ntoskrnl.exe!KeWaitForSingleObject+0x1460
ntoskrnl.exe!KeWaitForSingleObject+0x98f
ntoskrnl.exe!KeWaitForSingleObject+0x233
ntoskrnl.exe!ExWaitForRundownProtectionRelease+0x7dd
ntoskrnl.exe!KeWaitForSingleObject+0x3a29
ntoskrnl.exe!KiCheckForKernelApcDelivery+0x2b
ntoskrnl.exe!ExReleaseResourceAndLeaveCriticalRegion+0xc2
win32kbase.sys+0x9159f
win32kfull.sys!NtUserMsgWaitForMultipleObjectsEx+0x519
0x0000000000000000
win32u.dll!NtUserMsgWaitForMultipleObjectsEx+0x14
USER32.dll!MsgWaitForMultipleObjectsEx+0x9e
Qt5Core.dll!QEventDispatcherWin32::processEvents+0x394
qwindows.dll!qt_plugin_query_metadata+0x1dc9
LightBurn.exe+0x305402
LightBurn.exe+0xde774
LightBurn.exe+0x3f3d24
Qt5Core.dll!QMetaObject::activate+0x641
Qt5Widgets.dll!QAction::activate+0x10e
Qt5Widgets.dll!QAbstractButton::click+0x143
Qt5Widgets.dll!QAbstractButton::mouseReleaseEvent+0x8c
Qt5Widgets.dll!QToolButton::mouseReleaseEvent+0xf
Qt5Widgets.dll!QWidget::event+0xdc
Qt5Widgets.dll!QApplicationPrivate::notify_helper+0x140
Qt5Widgets.dll!QApplication::notify+0x7f3
Qt5Core.dll!QCoreApplication::notifyInternal2+0xb9
Qt5Widgets.dll!QApplicationPrivate::sendMouseEvent+0x3f3
Qt5Widgets.dll!QSizePolicy::QSizePolicy+0x2ab5
Qt5Widgets.dll!QSizePolicy::QSizePolicy+0xb45
Qt5Widgets.dll!QApplication::notify+0x1a97
Qt5Gui.dll!QGuiApplicationPrivate::processMouseEvent+0x8c1
Qt5Gui.dll!QWindowSystemInterface::sendWindowSystemEvents+0x92
Qt5Core.dll!QEventDispatcherWin32::processEvents+0xde6
USER32.dll!CallWindowProcW+0x3f8
USER32.dll!DispatchMessageW+0x259
Qt5Core.dll!QEventDispatcherWin32::processEvents+0x5b0
Qt5Core.dll!QEventLoop::exec+0x1cb
Qt5Core.dll!QCoreApplication::exec+0x141
LightBurn.exe+0xb09e
LightBurn.exe+0xb139
LightBurn.exe!FT_WriteEE+0x2bae94
LightBurn.exe!FT_WriteEE+0x2b9f5b
KERNEL32.DLL!BaseThreadInitThunk+0x14
ntdll.dll!RtlUserThreadStart+0x21
Guess this one is the main thread? At least it has the entry in the exe and runs the event loop.
This is the thread list:
And this is the second instance that’s also hanging:
ntoskrnl.exe!KeSynchronizeExecution+0x3140
Qt5Core.dll!QCoreApplicationPrivate::sendPostedEvents+0x27a
qwindows.dll!qt_plugin_query_metadata+0x1def
Qt5Core.dll!QEventDispatcherWin32::processEvents+0x682
LightBurn.exe+0x3066cd
LightBurn.exe+0xdfb5d
LightBurn.exe+0xf578b
Qt5Widgets.dll!QAbstractButton::clicked+0xa7
Qt5Widgets.dll!QAbstractButton::click+0x199
This thread also uses significant CPU time:
quartz.dll!AMGetErrorTextW+0x417b0
quartz.dll!AMGetErrorTextW+0x4208d
quartz.dll!AMGetErrorTextW+0x42837
quartz.dll!AMGetErrorTextW+0x3feee
quartz.dll!AMGetErrorTextW+0x3ddbe
quartz.dll!AMGetErrorTextW+0x3cfe5
quartz.dll!AMGetErrorTextW+0xfc031
quartz.dll!AMGetErrorTextW+0xfbac9
quartz.dll!AMGetErrorTextW+0x53b2
qcap.dll!DllCanUnloadNow+0x23e29
qcap.dll!DllCanUnloadNow+0x23cac
I’ll leave them running for now, so in the next couple of hours I can pull other diagnostics. (I’m frustrated that my laser went from “perfect cuts” to “halfway through is fine with you, ain’t it?” and I just can’t find the reason. Need. To. Do. Something. Completely. Different.)
Unfortunately I don’t see anything in there that I recognize. It looks like it might be hanging while waiting for a system resource of some kind, but I can’t think of anything in LightBurn itself that would do that.
One thing to try:
Open a Windows file explorer
Browse to C:\Program Files\LightBurn
Find the file ‘LBFileDialog.exe’
Rename it to something (just add .bak to the name, for example)
Re-run and see if you get the issue any more. We’ve had a small number of users (3 maybe?) report an issue with this, and I haven’t figured out why. The LBFileDialog program just shows the file open / save / import window, and passes information back to LightBurn. If it can’t be found, the software falls back to using the internal one instead of the launchable version.
Ok, I’ve renamed the LBFileDialog and will watch it closely.
One effect I already noticed: When I “Run GCode” the laser starts a fraction of a second after I confirm the File Open dialog now. This took 5-15 seconds before and from time to time it wouldn’t do anything. Hard to say if there’s a speed difference when opening lbrn2 files, there’s actual processing involved that needs CPU cycles.
system
(system)
closed
December 16, 2021, 5:33pm
#8
