Hello,
I have a custom-made openbuild GRBL laser, and I purchased my license in 2019, so I’m using version 0.9.06. Until now, I haven’t experienced any issues with it. However, after taking a break and resuming use this year, I’ve encountered a problem.
I engrave circular shapes and place a circular object on them to engrave a picture. The issue is that sometimes the software changes the coordinates unexpectedly. For example, if I set the coordinates to x:40, y:40, the laser might actually move to x:50, y:48. The strange thing is that afterward, the laser correctly returns to the right 0,0 coordinates.
Another issue I’ve noticed is when I move a circle from x:40, y:40 to x:60, y:40, the laser still engraves at the old x:40 position before moving to the correct 0,0 point.
I’m unsure what could be causing this. Could you please help?
This are my $$ config, I have not touched them and years ago it worked perfectly. Also I’ve checked the tension on the belts (this is not an issue because it DOES do a perfect circle), and also checked the wires (not an issue because all is working fine otherwise). On LaserGRBL this problem is not happening but IDK why on LB.
$0=10
$1=100
$2=0
$3=0
$4=0
$5=0
$6=0
$10=0
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=0
$24=200.000
$25=4000.000
$26=0
$27=1.000
$30=1000
$31=0
$32=1
$100=100.000
$101=100.000
$102=250.000
$110=4000.000
$111=4000.000
$112=500.000
$120=200.000
$121=200.000
$122=10.000
$130=500.000
$131=500.000
$132=200.000
Thanks in advance.
