LBRN files reading differently on two computers
Hello,
New to lightburn.I design the projects on my MAC and email the LBRN file to a PC that’s connected to the laser. When the file is opened on the PC it’s upside down to the orientation on the MAC. How can I solve this problem? I know its probably an obvious fix, but I’m new to Lightburn.
Many Thanks,
Lee
This is due to not having the Machine Origin set the same on both systems.
You need to ensure you have both installations of LightBurn set the same configuration on these systems. You need to use the same setup/device profile to have this transfer work as you’d expect. This includes having the same fonts available on both systems or you will need to bake these text elements into the file by converting text to paths first.
If you have the same on both systems, things will work as you want. I do it all the time. :wink: Back and forth and back again. Works great once set up properly.
Many thanks, I’ll give it a try.
