I have a new Boss Laser FM Station machine with Lightburn version 2.1.04 installed.
When marking with the rotary the lettering is distorted occasionally. What I think is happening is that the laser fires before the rotary has fully settled into position. Is there a dwell that can be adjusted to be sure the rotary is settled into position before firing the laser? Or a “wait for axis in-position” command that can be added?
I’d separate rotary settling from the galvo mirror delays before changing timing values. LightBurn’s 2.1 documentation describes Jump Delay and Laser On/Off TC as mirror-related settings, so they aren’t interchangeable with a rotary settling pause. In Rotary Setup, first save your existing values and check Max Speed and Acceleration Time. The official guide recommends reducing Max Speed and increasing Acceleration Time if the rotary loses steps or the workpiece slips. Try one change at a time on a small repeatable sample. Does the distortion appear immediately after each rotation, at slice boundaries, or throughout individual letters? Please share a close-up and screenshots of Rotary Setup and the Rotary Marking window. I haven’t verified a dedicated dwell control for your controller, so I wouldn’t suggest adding a generic command.
