I have an issue with lines not cutting/engraving and letters not cutting/engraving using our Gwieke Pro II. Cuts/engraving will not properly execute from my Macbook M2 Pro running Sonoma 14.0 and Lightburn software is updated. Letters have missing lines and lines are not complete when cutting/engraving a circle, square, etc. Can cut/engrave correctly from another Macbook M1 Air running the same version of OS and Lightburn.
Could you possibly take a full screenshot of your lightburn and a image of the results?
Also seeing that is a computer to compute issue
a) make sure tabs are not automaticaly set
b) make sure your M2 Pro lightburn is set to mm/min and not mm/sec (Edit/Settings)
c) make sure both Macs have the same settings on machine profiles (Edit/Device settings)
