Every time i start I Light Burn the library pops up how can i turn it off I don’t have anything in it yet.
until i hit ok on the pop up it the software will not load.
Thanks
Rudy
Thanks
Rudy
I suspect you mean you’re getting a pop-up saying that it couldn’t find the library file you used to have. If that’s happening, you’ve likely deleted it, but the software is trying to load it for you. In the Material Library window, click ‘New’ to reset it. That creates a new, unsaved, unnamed library, and since that is now the “current” library, it will be saved as your preference.
That worked thank you.
