kjone86
(Kevin Jones)
May 6, 2019, 2:30pm
1
I am unable to set origin on the machine. The only way I can get a print done is to start from current coordinates. No matter where I set the origin LighBurn tries to go to an origin that is off the work area cashing my machine to crash into the rails. I have an xcarve with x controller. I have uninstalled LightBurn and re flashed GRBL on my machine. It works fine with any other software. What could I be doing wrong?
raykholo
(Ray Kholodovsky)
May 6, 2019, 3:51pm
2
Start by having a look here:
[Return to main page](README.md)
# Common Grbl setups
If you have a GCode-based system, like a Shapeoko, Eleksmaker, X-Carve, or Acro system, you might need to make some simple changes to get the most from LightBurn.
#### Short version:
- You might need to adjust your spindle max RPM value ($30) to match the LightBurn default (1000) or vice versa. The value in LightBurn is called "S-Value Max", in the [Device Settings](DeviceSettings.md#s-value-max).
- You might need to enable "Laser Mode" if you have GRBL 1.1f or later (\$32=1).
- If your machine uses negative workspace coordinates you'll need to apply a workspace offset (G10 L2 P1 xx yy) and set your machine status reporting to be relative to the workspace origin, not the machine origin (\$10=0).
#### Grbl Flavors
Grbl firmware was originally designed for CNC machines and 3D printers, with laser support added more recently. It is highly configurable, and this is both a blessing and a curse. The "standard" way a CNC machine is configured is somewhat different than the way laser machines often are. Luckily this is easy to change, and easy to switch from one to the other.
This file has been truncated. show original
kjone86
(Kevin Jones)
May 8, 2019, 2:08am
3
I should have included I have been using the software for about 2 months without any issue. This is a recent occurrence. Before it worked perfectly.
raykholo
(Ray Kholodovsky)
May 8, 2019, 3:35am
4
Ok, I would still recommend verifying that you have the options set as described in that article.
system
(system)
Closed
May 22, 2019, 3:35am
5
