Select the text, then use Edit > Convert to Path.
It won’t be editable as text any more, but it will hold the shape without the path it was attached to.
Lightburn releases the latest version but when I tried to install the latest version then it shows an error windows defender error 577, so I want a solution on how to remove this error.
If you’re trying to download with Microsoft edge, try another browser. It seems they are flagging Google Drive downloads for some reason.
I see it says international text entry but I cannot find how to do so anywhere. Was making a design and wanted a different language. All I found was to change lightburns language but not the text when I type a word
You change the keyboard entry on your computer by adding a language to it, then type the text using the international keyboard settings. For example, 你好 is Hello in Chinese. I can type that here or in LightBurn because I have my keyboard set to flip between the two.
LightBurn simply respects the international settings of the operating system.
